Lift and reapply privacy masks
In some situations, you might need to review an area that's covered by a privacy mask. You cannot lift liftable privacy masks if you haven't been given the permissions to do so.
On the global toolbar, select Settings and more and Lift privacy mask.
If you have the right permissions, the liftable privacy masks now disappear. Permanent privacy masks still cover their areas.
If you don’t have sufficient user permissions, you'll see a window that asks you to contact a supervisor
To reapply the liftable privacy masks, select Settings and more and Apply privacy masks.
If you forget to reapply to reapply privacy masks, they are reapplied after a duration defined by your system administrator. The default duration is 30 minutes.
