Remove unnecessary cameras from video playback
"Before I play back the video, I want to remove the cameras that don’t contain any recordings within the time span that I’ve specified. How can I do that?" |
On the Investigations tab, you can remove the unnecessary cameras from a camera group if you:
- Hover over the camera
and then, in the upper right-hand corner, click
. - On the side panel, click
. - On the side panel, double-click the camera that you want to remove.
