MIP SDK upgrade error 2803
When upgrading the integration from an older version to a newer version, one of the components that is required to upgrade is the Milestone MIP SDK. During the upgrade process, the MIP SDK installation wizard can create an error if services or applications are still running which are using the MIP SDK files which are being upgraded.
It is recommended to continue the upgrade process, and simply restart all services and applications afterward to ensure they are using the newest versions of the required MIP SDK files. Please refer to the Milestone Knowledgebase troubleshooting article (number 37294) for more information.
