Filter your views
If you want to see a particular type of view only, or if you want to see fewer views, you can apply a filter. All views are displayed when you tap Filter, regardless of whether they are shown or filtered. You can always choose to include a view again.
How you filter views depends on the operating system on your device.
  1. To filter views:
    • Android - In the upper-right corner, tap . If a filter is already applied, the icon has a check mark
    • iOS - In the upper-right corner, tap . If a filter is already applied, the icon is blue
  2. To include or exclude a view, tap the view or use the slider.
  3. To apply the filter and return to the list of views:
    • iOS - In the upper-right corner, tap Done
Discard filter selections
If you haven't saved your selections yet, you can discard them:
  • Android - In the upper-left corner, tap
  • iOS - Undo your selections manually
