Issue: Inspelningsserver goes offline when switching Konfigurationsserver cluster node
If you set up a Microsoft cluster for Konfigurationsserver redundancy, the Inspelningsserver or Inspelningsservers may go offline when switching Konfigurationsserver between the cluster nodes.
To correct this, modify the following configuration settings:
On the Konfigurationsserver nodes:
- In C:\ProgramData\Milestone\XProtectKonfigurationsserver\ServerConfig.xml:
<AuthorizationServerUri>http://ClusterRoleAddress/IDP</AuthorizationServerUri>
- In C:\Program Files\Milestone\XProtectKonfigurationsserver\IIS\IDP\appsettings.json:
"Authority": "http://ClusterRoleAddress/IDP"
On the Inspelningsservers, verify that the authorizationserveraddress is also set to the cluster role address:
In C:\ProgramData\Milestone\XProtectInspelningsserver\RecorderConfig.xml:
<authorizationserveraddress>http://ClusterRoleAddress/IDP</authorizationserveraddress>
