Denna sida är ännu inte tillgänglig på ditt språk.
Requirements for privacy by design
Data minimization
You must ensure the personal data you are processing is:
adequate – enough to properly fulfill your stated purpose
relevant – has a rational link to that purpose
limited to what is necessary – you do not hold more than you need for that purpose.
Accuracy
Generally, for personal data:
You should take all reasonable steps to ensure the personal data you hold is not incorrect or misleading as to any matter of fact.
You may need to keep the personal data updated, although this will depend on what you are using it for.
If you discover that personal data is incorrect or misleading, you must take reasonable steps to correct or erase it as soon as possible.
You must carefully consider any challenges to the accuracy of personal data.
Storage period limitation
You must not keep personal data for longer than you need it.
You need to think about—and be able to justify—how long you keep personal data. This will depend on your purposes for holding the data.
You need a policy that sets standard retention periods wherever possible, to comply with documented requirements.
You should also periodically review the data you hold, and erase or anonymize it when you no longer need it.
You must carefully consider any challenges to your retention of data. Individuals have a right to erasure if you no longer need the data.
You may keep personal data for longer if you are only keeping it for public interest archiving, scientific or historical research, or statistical purposes.
