Standard References
The ONVIF driver relies on functionality from the following specifications:
Name
Version
Link
ONVIF Core
19.12
https://www.onvif.org/specs/core/ONVIF-Core-Specification.pdf
ONVIF Streaming
19.12
https://www.onvif.org/specs/stream/ONVIF-Streaming-Spec.pdf
Device IO
19.06
https://www.onvif.org/specs/srv/io/ONVIF-DeviceIo-Service-Spec.pdf
Imaging
19.06
https://www.onvif.org/specs/srv/img/ONVIF-Imaging-Service-Spec.pdf
Media
19.12
https://www.onvif.org/specs/srv/media/ONVIF-Media-Service-Spec.pdf
Media 2
19.12
https://www.onvif.org/specs/srv/media/ONVIF-Media2-Service-Spec.pdf
PTZ
18.12
https://www.onvif.org/specs/srv/ptz/ONVIF-PTZ-Service-Spec.pdf
Recording Search
18.12
https://www.onvif.org/specs/srv/rsrch/ONVIF-RecordingSearch-Service-Spec.pdf
Replay Control
17.06
https://www.onvif.org/specs/srv/replay/ONVIF-ReplayControl-Service-Spec.pdf
References to these specifications further in this document should be taken into account with the version specified here.
The ONVIF driver uses these services:
Name
Version
WSDL
Device
19.12
https://www.onvif.org/ver10/device/wsdl/devicemgmt.wsdl
Media
19.06
https://www.onvif.org/ver10/media/wsdl/media.wsdl
Media 2
19.06
https://www.onvif.org/ver20/media/wsdl/media.wsdl
Imaging
19.06
https://www.onvif.org/ver20/imaging/wsdl/imaging.wsdl
Event
19.06
https://www.onvif.org/ver10/events/wsdl/event.wsdl
Device IO
19.12
https://www.onvif.org/ver10/deviceio.wsdl
PTZ
17.06
https://www.onvif.org/ver20/ptz/wsdl/ptz.wsdl
Recording Search
2.4.2
https://www.onvif.org/ver10/search.wsdl
Replay Control
18.06
https://www.onvif.org/ver10/replay.wsdl
References to these services further in this document should be taken into account with the version specified here.
