Show/edit port numbers
- Right-click the Mobile Server Manager icon and select Show/edit port numbers.
- To edit the port numbers, enter the relevant port number. You can indicate a standard port number for HTTP connections or a secured port number for HTTPS connections, or both.
- Click OK.
