Adaptive streaming (explained)
XProtect Mobile supports adaptive streaming in live mode (for XProtect Expert and XProtect Corporate only).
Adaptive streaming is useful when you view multiple live video streams in the same view of cameras. The feature optimizes the performance of the XProtect Mobile server and improves the decoding capability and performance of devices that are running XProtect Mobile client and XProtect Web Client.
To take advantage of adaptive streaming, your cameras must have multiple streams defined with different resolutions. In this case, the feature allows you to:
Optimize video quality - selects the stream with the lowest available resolution that is equal to or higher than the requested resolution
Optimize server performance - reduces the requested resolution and then selects the stream with the lowest available resolution that is equal to or higher than the reduced request
Optimize resolution for low bandwidth - selects the stream with the lowest available resolution (recommended if you use 3G or an unstable network)
When zooming, the live video stream requested is always the one with the highest available resolution.
Bandwidth usage is often reduced when the resolution of the requested streams is reduced. Bandwidth usage also depends on other settings in the configurations of the defined streams.
Para obtener más información, consulte el manual de administrator para XProtect VMS.
