Removing device drivers (explained)
If you no longer require device drivers on your computer, you can delete the device packs from your system. To do so, follow the standard Windows procedure for removing programs.
If you have multiple device packs installed and have problems deleting the files, you can use the script in the device pack installation folder to delete them completely.
If you remove device drivers, the recording server and the camera devices cannot communicate any longer. Do not remove device packs when you upgrade because you can install a new version on top of an old one. Only if you uninstall the entire system, you may remove the device pack.
