Site Navigation: Clients: Management Client profiles
可用的功能取决于正在使用的系统。有关详细信息,请参阅 https://www.milestonesys.com/solutions/platform/product-index/
Management Client profiles allow system administrators to modify the Management Client user interface for other users. Associate Management Client profiles with roles to limit the user interface to represent the functionality available for each administrator role.
To associate a role with a Management Client profile, see the Role Settings' Info tab (see Roles settings).Management Client profiles only handle the visual representation of system functionality, not the actual access to it. To limit the overall access to system functionality for a role, see the Role Settings' Overall Security tab (see Management ClientRoles settings).
It is important that all roles, to have access to the Management Server, enable the Connect security right, located in Role Settings > Management Server > Roles settings.
You can change settings for the visibility of all Management Client elements. By default, the Management Client profile can see all functionality in the Management Client.
  • To limit visibility of functionality, clear the check boxes for the relevant functionality in order to remove the functionality visually from the Management Client for any Management Client user with a role associated with this Management Client profile
Apart from the built-in administrator role, only users associated with a role that has been granted Manage security permissions for the management server on the Overall Security tab, can add, edit, and delete Management Client profiles.
Add and configure a Management Client profile
If you do not want to use the default profile, you can create a Management Client profile before you can configure it.
  1. Right-click Management Client Profiles.
  2. Select Add Management Client Profile.
  3. In the Add Management Client Profile dialog box, enter a name and description of the new profile and click OK.
  4. In the Overview pane, click the profile you created to configure it.
  5. On the Profile tab, select or clear functionality from the Management Client profile.
Copy a Management Client profile
If you have a Management Client profile with settings that you would like to reuse, you can copy an already existing profile and make minor adjustments to the copy instead of creating a new profile from scratch.
  1. Click Management Client Profile, right-click the profile in the Overview pane, select Copy Management Client Profile.
  2. In the dialog box that appears, give the copied profile a new unique name and description. Click OK.
  3. In the Overview pane, click the profile and go to the Info tab or Profile tab to configure the profile.
Management Client profile properties
Info tab (Management Client Profiles)
On the Info tab, you can set the following for Management Client profiles:
Component
Requirement
Name
Enter a name for the Management Client profile.
Priority
Use the up and down arrows to set a priority for the Management Client profile.
Description
Enter a description for the profile. This is optional.
Roles using the Management Client profile
This field shows the roles that you have associated with the Management Client profile. You cannot edit this.
Profile tab (Management Client Profiles)
On the Profile tab, you can enable or disable the visibility of the following elements from the Management Client's user interface:
Navigation
In this section, decide if an administrator user associated with the Management Client profile is allowed to see the various features and functionality located in the Navigation pane.
Navigation element
Description
Basics
Allows the administrator user associated with the Management Client profile to see License Information and Site Information.
Remote Connect Services
Allows the administrator user associated with the Management Client profile to see Axis One-click Camera Connection.
Servers
Allows the administrator user associated with the Management Client profile to see Recording Servers and Failover Servers.
Devices
Allows the administrator user associated with the Management Client profile to see Cameras, Microphones, Speakers, Metadata, Input and Output.
Client
Allows the administrator user associated with the Management Client profile to see Smart Wall, View Groups, Smart Client Profiles, Management Client Profiles and Matrix.
Rules and Events
Allows the administrator user associated with the Management Client profile to see Rules, Time Profiles, Notification Profiles, User-defined Events, Analytics Events and Generic Events.
Security
Allows the administrator user associated with the Management Client profile to see Roles and Basic Users.
System Dashboard
Allows the administrator user associated with the Management Client profile to see System Monitor, System Monitor Thresholds, Evidence Lock, Current Tasks and Configuration Reports.
Server Logs
Allows the administrator user associated with the Management Client profile to see system, audit, and rule-triggered logs.
Access Control
Allows the administrator user associated with the Management Client profile to see Access Control features, if you have added any access control system integrations or plug-ins to your system.
Details
In this section, decide if an administrator user associated with the Management Client profile is allowed to see the various tabs for a specific device channel, for example the Settings tab or Record tab for cameras.
Device channel
Description
Cameras
Allows the administrator user associated with the Management Client profile to see some or all camera-related settings and tabs.
Microphones
Allows the administrator user associated with the Management Client profile to see some or all microphone-related settings and tabs.
Speakers
Allows the administrator user associated with the Management Client profile to see some or all speaker-related settings and tabs.
Metadata
Allows the administrator user associated with the Management Client profile to see some or all metadata-related settings and tabs.
Input
Allows the administrator user associated with the Management Client profile to see some or all input-related settings and tabs.
Output
Allows the administrator user associated with the Management Client profile to see some or all output-related settings and tabs.
Tools Menu
In this section, decide if an administrator user associated with the Management Client profile is allowed to see the elements that are part of the Tools menu.
Tool Menu option
Description
Registered Services
Allows the administrator user associated with the Management Client profile to see Registered Services.
Effective Roles
Allows the administrator user associated with the Management Client profile to see Effective Roles.
Options
Allows the administrator user associated with the Management Client profile to see Options.
Federated Sites
In this section, decide if an administrator user associated with the Management Client profile is allowed to see the Federated Site Hierarchy pane.
