VMS system administrator
System administrators are responsible for setting up the GDPR compliant system environment. System administrators do amongst the following:
  • Apply and maintain a high general security level by following the Hardening Guide (see the Milestone Hardening Guide)
  • Apply a secure password policy
  • Conduct security audits
  • Ensure devices record according to the defined purpose – for example, on event, motion, always-on, and so forth
  • Ensure recording and audit log retention time is set according to local law and the defined purpose of the VMS
  • Ensure user management (add / remove users)
  • Ensure cameras follow privacy laws and do not record areas that should not be recorded – mask out areas that should not be recorded
  • Contact the Data Protection Officer (DPO) if GDPR non-compliance is suspected, for example, in the case of data breach of video materials (see Appendix: GDPR compliance)
