Install System Watch
  1. Run the installer. Depending on your security settings, you may receive one or more security warnings. Click the Run button if you receive a warning.
  2. When the installation wizard starts, select language for the installer and then click Continue.
  3. Read and accept the license agreement, and indicate if you want to participate in the Milestone data collection program.
  4. Select Typical or Custom installation. If you select Custom installation, you can select application language and where to install System Watch. Select a user for the service account. If the computer is part of a domain, you must either define the service as a network service or a domain user account.
    • If you choose This preferred account, System Watch installs a network service account
    • If you choose This account, you can browse for a domain user in your network user database that has rights to access both the computer running System Watch and the computer running the XProtect surveillance system. Provide the password assigned to the selected user account
  5. Click Continue to complete the setup.
