Denne side er endnu ikke tilgængelig på dit sprog.
What should you do?
Document the resolution of different points in the camera scene
Document the intended retention time
Consider applying privacy masking – permanent or liftable
Consider setting up permissions for viewing live videos, recordings
Consider restricting access for exporting recordings and for lifting privacy masks
Regularly review roles and responsibilities for operators, investigators, system administrators and others with access to the system
Consider restricting access to groups tasked with investigations for cameras that are specifically positioned to capture identity (for example, faces of people entering a store)
Consider restricting access to recorded video for operators, either completely, to only the video recorded in the past few hours, or only with dual authorization
Limit the number of users who have an Administrator Role
