Back view
Connectors | ||
1. Power switch | 6. 4 x USB 3.0 ports | 11. eSATA storage port |
2. Power supply | 7. LAN port 2 | 12. I/O connector |
3. DVI display port | 8. Audio MIC | 13. PoE+ network switch 16 x 1Gb/s (Option) |
4. HDMI display port | 9. Audio OUT | 14. QR code for support and information |
5. LAN port 1 | 10. Audio IN | 15. Label with serial number |
LED status indicators | LED colors |
16. LAN ports activity | Flashing yellow |
17. LAN ports link speed | Yellow = 100Mb/s. Green = 1Gb/s. Off = 10Mb/s |
18. PoE switch LAN ports activity | Flashing yellow |
19. PoE switch LAN ports power delivery | Green means OK / Red means failure |
Var denna artikel till hjälp?
Tack för din respons!
