Denna sida är ännu inte tillgänglig på ditt språk.
Remove a customer
If you no longer work with a specific customer or want to free up the associated licenses, you can remove the customer from Milestone Customer Dashboard.
When you remove a customer, all associated licenses are listed as Unspecified on the Licenses page.
  1. In the main menu, select Customers .
  2. Select the customer that you want to rename and select Details .
  3. Select Remove customer .
  4. Select Yes to confirm that you want to remove the customer.
