Эта страница еще не доступна на вашем языке.
Change the Software License Code
If you run your installation on a temporary Software License Code (SLC) during the first period or have upgraded to a more advanced XProtect product, you can change your SLC without any un- or reinstallation actions when you have received your new software license file.
This must be done locally on the management server. You cannot do this from the Management Client.
  1. On the management server, go to the notification area of the taskbar.
  2. Right-click the Management Server icon and select Change License.
  3. Click Import License.
  4. Next, select the software license file saved for this purpose. When done, the selected software license file location is added just below the Import License button.
  5. Click OK and you are now ready to register SLC. See Register Software License Code.
