Deze pagina is nog niet beschikbaar in uw taal.
What should you do?
  • Document the resolution of different points in the camera scene
  • Document the intended retention time
  • Consider applying privacy masking – permanent or liftable
  • Consider setting up permissions for viewing live videos, recordings
  • Consider restricting access for exporting recordings and for lifting privacy masks
  • Regularly review roles and responsibilities for operators, investigators, system administrators and others with access to the system
  • Consider restricting access to groups tasked with investigations for cameras that are specifically positioned to capture identity (for example, faces of people entering a store)
  • Consider restricting access to recorded video for operators, either completely, to only the video recorded in the past few hours, or only with dual authorization
  • Limit the number of users who have an Administrator Role
