Questa pagina non è ancora disponibile nella lingua richiesta.
Run the VMS on a dedicated network
Milestone recommends that, whenever possible, you separate the network where the VMS is running from networks with other purposes. For example, a shared network such as the printer network should be isolated from the VMS network. In addition, XProtect VMS deployments should follow a general set of best practices for system interconnections.
Learn more
The following control(s) provide additional guidance:
  • NIST SP 800-53 CA-3 System Interconnections
