Questa pagina non è ancora disponibile nella lingua richiesta.
Daylight saving time (explained)
Daylight saving time (DST) is the practice of advancing clocks for evenings to have more daylight and mornings to have less. The use of DST varies between countries/regions.
When you work with a surveillance system, which is inherently time-sensitive, it is important that you know how the system handles DST.
Do not change the DST setting when you are in the DST period or if you have recordings from a DST period.
