Questa pagina non è ancora disponibile nella lingua richiesta.
Change the language
You can change the language of the Milestone Customer Dashboard interface and system reports. To change the language:
  1. In the upper right-hand corner, select your login name, then select User settings .
  2. On the User settings page, under Language and region, select the desired language in the Language dropdown list .
  3. Select Save to apply the changes.
