Adjust the token time-out
XProtect VMS uses session tokens when it logs in to the management server using SSL (basic users) or NTLM (Windows users) protocols. A token is retrieved from the management server and used on the secondary servers, for example the recording server and sometimes also the event server. This is to avoid that NTLM and AD lookup is performed on every server component.
By default, a token is valid for 240 minutes. You can adjust this down to 1 minute intervals. This value can also be adjusted over time. Short intervals increase security, however, the system generates additional communication when it renews the token.
The best interval to use depends on the deployment. This communication increases the system load and can impact performance.
Learn more
The following control(s) provide additional guidance:
- NIST SP 800-53 IA-5 Authenticator Management
Cet article vous a-t-il aidé ?
Merci de votre avis.
