This page is not yet available in your language.
Use port-based access control
Use port-based access control to prevent unauthorized access to the camera network. If an unauthorized device connects to a switch or router port, the port should become blocked. Information about how to configure switches and routers is available from the manufacturers. See SP 800-128, Guide for Security-Focused Configuration Management of Information Systems (http://csrc.nist.gov/publications/nistpubs/800-128/sp800-128.pdf), for information about configuration management of information systems.
Learn more
The following control(s) provide additional guidance:
  • NIST 800-53 CM-1 Configuration Management Policy and Procedures
  • NIST 800-53 CM-2 Baseline Configuration
  • NIST 800-53 AC-4 Least Privilege
  • NIST 800-53 CM-6 Configuration Settings
  • NIST 800-53 CM-7 Least Functionality
