Your new Milestone Husky™ X2
You have just received:
- Milestone Husky™ X2
- Hard drives (if ordered from Milestone)
- Hard drive trays
- Power cable
- Getting started guide
- Warranty agreement
You can use your Milestone Husky™ X2 in different setups depending on your system requirements:
- Standalone installation
- Multi-unit installation, where one Milestone Husky X2 takes the role of the management server and the recording server, while other Milestone Husky X2 units are installed as recording servers
- Milestone Husky X2 as the recording server in an existing XProtect system
Note these flexible features:
- Milestone Husky X2 is shipped with XProtect video management software pre-loaded
- Husky Assistant completes the installation of XProtect to optimize the use of Milestone Husky X2
- Milestone Husky X2 can be used with any version of the five XProtect VMS products by entering a valid software license code (SLC)
Milestone Husky X2 exists in two models: HX2P16 and HX2, with or without a 16 x 1Gb/s PoE+ capable network switch. This guide covers both models. The following sections will take you through the minimum steps to get started with your Milestone Husky X2:
For more product information and support, go to the Milestone Husky X2 product information web page (https://www.milestonesys.com/HuskyX2-support/). You can also use your mobile phone to scan the QR code on the back of the unit. This will take you to the same web page.
Remember to check the Milestone website (https://www.milestonesys.com/downloads/) for updates to the Husky Tools Installer, which gives you the most recent version of Husky Assistant.
Was this article helpful?
Thanks for your feedback!
