Camera settings
Verify the recommended camera settings in the Management Client:
- Frames per second: 25 (or more)
- Maximum frames between keyframes: 25 (same value as frames per second)
- Resolution: 1920x1080
- Bit rate control mode: Constant bit rate
Was this article helpful?
Thanks for your feedback!
