Tato stránka zatím není k dispozici ve vašem jazyce.
Upgrade in a cluster
Make sure to have a backup of the database before updating the cluster.
  1. Stop the Management Server service on all management servers in the cluster.
  2. Uninstall the management server on all servers in the cluster.
  3. Use the procedure for installing multiple management servers in a cluster as described for install in a cluster. Refer to Install a new XProtect system.
When installing, make sure to reuse the existing SQL Server and the existing SQL database that currently stores the system configuration. The system configuration is automatically upgraded.
