Initial configuration tasks list
The checklist below lists the initial tasks for configuring your system. Some of them, you may already have completed during installation.
A completed checklist does not in itself guarantee that the system matches the exact requirements of your organization. To make the system match the needs of your organization, Milestone recommends that you monitor and adjust the system continuously.
For example, it is a good idea to test and adjust the motion detection sensitivity settings of individual cameras under different physical conditions, including day/night and windy calm weather, once the system is running.
The setup of rules, which determine most of the actions your system performs, including when to record video, is another example of configuration that you can change according to your organization's needs.
Step |
Description |
You have finished the initial installation of your system. |
Change the trial SLC to a permanent SLC (if required). |
Log in to the Management Client. See Login overview. |
Verify that each recording server's storage settings meet your needs. |
Verify that each recording server's archiving settings meet your needs. |
Detect the hardware, cameras or video encoders to add to each recording server. See Add hardware. |
Configure each recording server's individual cameras. |
Enable storage and archiving for individual cameras or for a group of cameras. This is done from the individual cameras or from the device group. |
Enable and configure devices. |
Rules determine the system's behavior to a large extent. You create rules to define when cameras should record, when pan-tilt-zoom (PTZ) cameras should patrol, and when notifications should be sent, for example. Create rules. |
Add roles to the system. See Roles (explained). |
Add users or groups of users to each of the roles. |
Activate licenses. |
See also Configuring the system in the Site Navigation pane.
Byl tento článek užitečný?
Děkujeme za vaši zpětnou vazbu!
