Web pages (troubleshooting)
The web page uses scripts that are not supported by the browser used to render the web page. It may resolve the issue to change the Display mode in the web page properties.
- Have you set Display mode to Compatibility? Only Compatibility mode supports scripting.
 - Have you used the correct syntax in your HTML code?
 - Is HTML scripting enabled in XProtect Management Client or in the Client.exe.config file?
 - Does the intended audience have the user rights to access certain cameras, views, features, or tabs in XProtect Smart Client?
