Feature overview
The features available in XProtect Smart Client depend on your user rights and which of these products that you are using:
  • XProtect Corporate
  • XProtect Expert
  • XProtect Professional+
  • XProtect Express+
  • XProtect Essential+
For information about the features available in your XProtect VMS, see Surveillance system differences.
Name
Description
Workspaces
Task-oriented tabs:
  • Live
  • Playback
  • Search
  • Alarm Manager
  • System Monitor
Tabs for XProtect add-ons:
  • Access Control for XProtect Access
  • LPR for XProtect LPR
  • Transact for XProtect Transact
General features and personalization
  • Toggle between light and dark themes
  • Toggle between a simplified and an advanced workspace
  • Customize the general behavior and look of XProtect Smart Client, for example the availability of control panes and functions. It can also be centrally enforced by the system administrator through Smart Client profiles
  • You can make advanced application settings, for example multicasting, hardware acceleration, video diagnostics overlay, and time zone settings
  • Use shortcuts to select specific windows or cameras in a window
  • Search for cameras and views, and create temporary views for the cameras on the fly
  • Create keyboard shortcuts to quickly execute commands
  • Configure joystick controls
  • You can configure the behavior of alarms and access control notifications
  • You can change the application language
View handling
  • Set up views that show video from 1-100 cameras per monitor or view
  • Centralized storage of shared and private camera views allowing other operators using the system to access the views
  • Choose between different view layouts optimized for 4:3 and 16:9 display settings in both landscape and portrait modes
  • Support for multiple windows, where you can operate secondary windows in independent playback mode or in synchronized mode
  • Distribute camera views over different monitors
  • Add other types of content to views than just cameras, for example alarms, camera navigators, carousels, hotspots, HTML pages, images, smart map, maps, Matrix, video walls, and text
  • Switch to full screen mode
  • Instantly rearrange cameras in views to optimize monitoring of incidents, either by dragging and dropping cameras from one view item to another, or by dragging cameras from the Cameras pane into any view item
Matrix
Through the Matrix, send or receive video from any camera to any Matrix recipient on your network.
Alarm handling
  • Get a consolidated and clear overview of security and system-related alarms
  • Use the alarm list or desktop notifications to respond to alarms and preview the incidents that caused the alarms
  • The alarm list and alarm preview are located on the Alarm Manager tab, but you can add them to any view
  • Filter and sort alarms, for example by priority or source
  • Search for alarms on the Search tab
  • Receive instructions through the alarms so that you can take immediate action
  • Escalate and forward alarms
  • Create alarm reports to document incidents
  • Suppress alarms from specific devices
  • If you are using Milestone Federated Architecture™, get an overview of alarms across all connected sites
Audio
With two-way audio support in live mode, you can:
  • Record live audio from microphones connected to the cameras
  • Play audio from the operator's microphone to one or more camera speakers
Bookmarks and search
  • Bookmark incidents in live, playback, and search mode. Add notes to the bookmarks for easy identification and sharing
  • Bookmark multiple search results in one go
  • Find bookmarks through search and take further action, for example editing the details or exporting the recording
Bounding boxes
Enable bounding boxes to help you identify objects in a camera image. Bounding boxes appear as yellow rectangles surrounding objects.
Camera navigator
Switch between all cameras that cover a specific area, for example a floorplan. This is useful, for example, if you want to follow a suspect who moves inside a building. As the person moves, you can switch to the next camera.
Carousels
If you want one view item to shift between selected cameras, set up a carousel.
Centralized search
  • Perform advanced searches on the Search tab, and take immediate action based on your search results, for example bookmarking or exporting of search results
  • With smart map, you can view the geographic location of your cameras while searching
  • Match all or any of the search criteria
Digital zoom
Use digital zoom to see the details.
Evidence locks
  • Prevent recordings from being deleted for a selected set of cameras in a given time interval
  • To increase manageability of the evidence locks, you can add details to them
  • Export video with evidence locks through a single-step operation
Export and print
Hardware acceleration
Improve the video quality and viewing performance by rendering video using hardware accelerated decoding. Particularly useful when you view multiple video streams that have a high frame rate and high resolution.
Hotspots
  • Use hotspots to put a camera in a view into focus. This allows you to view the video magnified and in a higher image quality or frame rate, for example if the other cameras in the view are in a low image quality or frame rate
  • Through local hotspots, you can display cameras from the current view
  • Through global hotspots, you can display cameras from any view or display
HTML pages
Incorporate HTML pages into your views, for example to combine an online news channel with a set of cameras.
Independent playback
View recorded video independently of the timeline in the main window. Available on both the Live and Playback tab.
Input, output, and events control
  • Use input from external units to trigger rules in the VMS system, for example a rule that starts recording
  • Activate or deactivate functionality in output devices, for example starting or stopping a siren. You can control output devices manually or by setting up rules server-side
Login authorization
Increase the system security by enforcing that XProtect Smart Client operators during log-in must be granted access to the system by a second person or supervisor.
Manual recording
Record video manually from cameras on the Live and Playback tab.
Map function
  • Add multi-layered and interactive maps that display the location of cameras and gives you control of all system components
  • Maps can represent cities, streets, buildings, and rooms
  • The map feature is integrated with XProtect Smart Wall
Motion search and smart search
  • Search for recordings with motion on the Search tab
  • Search for recordings with motion in selected areas on the Search tab
Playback timeline
  • Navigate recordings through the timeline
  • Play back video fast and slowly
  • Jump to date and time
  • Jump to the next or previous image
  • Jump to the first or previous sequence
  • Set the time span for the timeline
  • Get a visual overview of recordings, motion, and bookmarks through colored markers
  • Select time interval for exports, evidence locks, and video retrieval from edge storage devices and interconnected systems
Privacy masks
During export, you can mask specific areas in the recordings, for example to hide the identify of someone. You do this one camera at a time.
PTZClosedPan-tilt-zoom; a highly movable and flexible type of camera.
Smart map function
Snapshots
Take instant snapshots from cameras on the Live and Playback tab.
Storyboarding
Include video sequences from different or overlapping time intervals from different cameras in the same export.
System monitoring
Get an overview of the current state of your servers, connected devices, and the computer running XProtect Smart Client. This includes system performance.
XProtect Smart Wall
Through XProtect Smart Wall, you can set up video walls to share video, alarms, maps, bookmarks, and text information with other operators.
User interface languages
Supported languages:
  • Arabic
  • Bulgarian
  • Croatian
  • Chinese (simplified)
  • Chinese (traditional)
  • Czech
  • Danish
  • Dutch
  • English
  • Farsi
  • Finnish
  • French
  • German
  • Hebrew
  • Hindi
  • Hungarian
  • Icelandic
  • Italian
  • Japanese
  • Korean
  • Norwegian (bokmål)
  • Polish
  • Portuguese (Brazilian)
  • Russian
  • Serbian
  • Slovak
  • Spanish
  • Swedish
  • Thai
  • Turkish
  • Ukrainian
Help languages
The help function (F1 key) is available in these languages:
  • Arabic
  • Czech
  • Danish
  • Dutch
  • English
  • French
  • German
  • Italian
  • Japanese
  • Korean
  • Polish
  • Russian
  • Spanish
  • Swedish
  • Turkish
