Site Navigation: Clients
This article describes how to customize the user interface for operators in XProtect Smart Client and for system administrators in the Management Client.
Clients (explained)
Available functionality depends on the system you are using. See https://www.milestonesys.com/solutions/platform/product-index/ for more information.
The Client section of the Management Client consists of:
Name |
Description |
XProtect Smart Wall |
XProtect Smart Wall is an add-on that allows you to send view content from XProtect Smart Client to a dedicated video wall. For more detailed information about XProtect Smart Wall, see XProtect Smart Wall (explained). |
View groups |
The way in which video from cameras is presented is called a view. To control who can see what in XProtect Smart Client, you can create view groups to group views in logical entities. You can assign access to these view groups through roles and limit who can access individual view groups to specific roles. Select View Groups to design and work with view groups to fit your surveillance needs. |
Smart Client profiles |
To differentiate XProtect Smart Client users, you can create Smart Client profiles, prioritize these and customize their profiles as needed for the different tasks at hand. |
Management Client profiles |
To differentiate Management Client administrator users, you can create Management Client profiles, prioritize these and customize their profiles as needed for the different tasks at hand. |
Matrix |
Matrix is a feature for distributing video remotely. If you use Matrix, you can push video from any camera on your system's network to any running XProtect Smart Client. |
