Use picture-in-picture
If you see something that you want to investigate, but you don't want to stop observing the current situation, then you can display the live video in picture-in-picture (PiP) and simultaneously play back the video.
To turn on picture-in-picture (PiP):
  1. Switch from live mode to playback mode by tapping (Android) or (iOS).
  2. Depending on the operating system on your device:
    • Android - Tap
    • iOS - Tap
    The incoming audio is not available in PiP.
    To move the PiP window, tap and hold, and drag the PiP window to the preferred place on the screen.
Return to live video
To view the live video in full screen:
  • Double-tap the PiP window
  • Tap (Android) or (iOS)
