Matrix (configuration)
Add Matrix to views
To be able to send live video to a Matrix
A product integrated into some surveillance systems, which enables the control of live camera views on remote computers for distributed viewing. Computers on which you can view Matrix-triggered video are known as Matrix-recipients.-recipient, first you must add the Matrix item to a view. Only from within the view, can the operator send the video to a Matrix-recipient.
- In setup mode, in the System Overview pane, drag the Matrix item to the position in the view where you want to add Matrix content. A blue border appears indicating that the position in the view has Matrix content.
- When you select a Matrix position, you can specify its properties in the Properties pane.
When viewing live or recorded video, you can double-click a Matrix position (or any other camera position in a view) to maximize it. When maximized, video from cameras in the Matrix position is displayed in full quality by default, regardless of your image quality selection. If you want to make sure that the selected image quality also applies when maximized, select Keep when maximized.
- Repeat for each Matrix position you want to add.
Matrix settings
In setup mode, in the Properties (see Camera settings) pane, you can specify the settings for Matrix
A product integrated into some surveillance systems, which enables the control of live camera views on remote computers for distributed viewing. Computers on which you can view Matrix-triggered video are known as Matrix-recipients. positions.
Name |
Description |
| Window index |
Change the Matrix position's ranking by choosing a different number. You can only choose a number in the range that corresponds to the number of Matrix positions in your view. 1 is the primary position in which video from the newest event is always shown, 2 displays video from the previously detected event, 3 displays video from the event detected before the event in position 2, and so on. |
| Connection Settings... |
Lets you specify the TCP |
