Hotspots (configuration)
Before you can use the hotspot
A particular position for viewing magnified and/or high quality camera images in XProtect Smart Client views., you must:
- Add the hotspot to a view. See Add hotspots to views.
- Specify the hotspot settings. See Hotspot settings.
If your view contains a hotspot, and you click a camera, the video feed from the camera is displayed in a high resolution in the hotspot
A particular position for viewing magnified and/or high quality camera images in XProtect Smart Client views. view item.
Steps:
- Click Setup to enter setup mode.
- In the System Overview pane, click and drag the Hotspot item to the required position in the view. The position displays a hotspot icon:
. - Click Setup again to exit the setup mode.
- (optional) To set the properties for the hotspot, in setup mode, go to the Properties pane.
To save bandwidth, you can specify a low image quality for the other positions in your view and a high quality for the hotspot.
Hotspot settings
In the Properties (see Camera settings) pane, you can specify the settings for the hotspot
A particular position for viewing magnified and/or high quality camera images in XProtect Smart Client views.. The Live Stream, Image Quality, Frame Rate, and Maintain Image Aspect Ratio settings apply to all cameras in the hotspot.
To make the properties appear, you must select the view item and then click Setup.
