Minimum system requirements
For information about the minimum system requirements to the various components of your system, go to the Milestone website (https://www.milestonesys.com/systemrequirements/).
To view information about your system, for example the operating system and version of DirectX, and the devices and drivers installed:
- Click Start, select Run and type dxdiag. When you click OK, the DirectX Diagnostic Tool window opens
The version information is displayed near the bottom of its System tab. Should the server require a DirectX update, the latest versions of DirectX are available from the Microsoft website (https://www.microsoft.com/downloads/).
