Feature overview
The features available in XProtect Smart Client depend on your user rights and which of these products that you are using:
- XProtect Corporate
- XProtect Expert
- XProtect Professional+
- XProtect Express+
- XProtect Essential+
For information about the features available in your XProtect VMS, see Surveillance system differences.
Name |
Description |
| Workspaces |
Task-oriented tabs:
Tabs for XProtect add-ons:
| General features and personalization |
| View handling |
| Matrix |
Through the Matrix, send or receive video from any camera to any Matrix recipient on your network. |
| Alarm handling |
| Audio |
With two-way audio support in live mode, you can:
| Bookmarks and search |
| Bounding boxes |
Enable bounding boxes to help you identify objects in a camera image. Bounding boxes appear as yellow rectangles surrounding objects. |
| Camera navigator |
Switch between all cameras that cover a specific area, for example a floorplan. This is useful, for example, if you want to follow a suspect who moves inside a building. As the person moves, you can switch to the next camera. |
| Carousels |
If you want one view item to shift between selected cameras, set up a carousel. |
| Centralized search |
| Digital zoom |
Use digital zoom to see the details. |
| Evidence locks |
| Export and print |
| Hardware acceleration |
Improve the video quality and viewing performance by rendering video using hardware accelerated decoding. Particularly useful when you view multiple video streams that have a high frame rate and high resolution. |
| Hotspots |
| HTML pages |
Incorporate HTML pages into your views, for example to combine an online news channel with a set of cameras. |
| Independent playback |
View recorded video independently of the timeline in the main window. Available on both the Live and Playback tab. |
| Input, output, and events control |
| Login authorization |
Increase the system security by enforcing that XProtect Smart Client operators during log-in must be granted access to the system by a second person or supervisor. |
| Manual recording |
Record video manually from cameras on the Live and Playback tab. |
| Map function |
| Motion search and smart search |
| Playback timeline |
| Privacy masks |
During export, you can mask specific areas in the recordings, for example to hide the identify of someone. You do this one camera at a time. |
| PTZ |
| Smart map function |
| Snapshots |
Take instant snapshots from cameras on the Live and Playback tab. |
| Storyboarding |
Include video sequences from different or overlapping time intervals from different cameras in the same export. |
| System monitoring |
Get an overview of the current state of your servers, connected devices, and the computer running XProtect Smart Client. This includes system performance. |
| XProtect Smart Wall |
Through XProtect Smart Wall, you can set up video walls to share video, alarms, maps, bookmarks, and text information with other operators. |
| User interface languages |
Supported languages:
| Help languages |
The help function (F1 key) is available in these languages:
