Disable the help
To prevent operators
A professional user of an XProtect client application. from accessing the help function, you can disable the help. Then nothing happens when you press F1, and the context-sensitive links and Help buttons are no longer visible. If required, you can enable the help again.
The availability of the help can also be controlled server-side by your system administrator. You can only disable or enable the help if the system administrator has not locked this setting.
Steps:
Open the Settings window. It opens on the Application tab.
- In the Online help list, select Unavailable.
- Close the dialog.
- To test that the help has been disabled, press F1. Nothing should happen.
