This page is not yet available in your language.
Connection to the SQL Server and database
Communication between the Milestone XProtect VMS and the SQL Server and database can potentially be tampered by an attacker because the certificate is not validated.
To mitigate this, you must first set up verifiable server certificates. After the certificates are set up, you must modify the ConnestionString in the Windows registry by removing trustServerCertificate=true, as follows:
Registry key: Computer\HKEY_LOCAL_MACHINE\SOFTWARE\VideoOS\Server\Common\ConnectionString
  • Current
    connection string: Data Source=localhost;initial catalog='Surveillance';Integrated Security=SSPI;encrypt=true;trustServerCertificate=true
  • Hardened
This results in encryption occurring only if there is a verifiable server certificate, otherwise the connection attempt fails.
This issue is described in detail in the article Using Encryption Without Validation.
