This page is not yet available in your language.
Secure communication (explained)
Hypertext Transfer Protocol Secure (HTTPS) is an extension of the Hypertext Transfer Protocol (HTTP) for secure communication over a computer network. In HTTPS, the communication protocol is encrypted using Transport Layer Security (TLS), or its predecessor, Secure Sockets Layer (SSL).
In XProtect VMS, the secure communication is obtained by using SSL/TLS with asymmetric encryption (RSA).
SSL/TLS uses a pair of keys—one private, one public—to authenticate, secure, and manage secure connections.
A certificate authority (CA) can issue certificates to web services on servers using a CA certificate. This certificate contains two keys, a private key and public key. The public key is installed on the clients of a web service (service clients) by installing a public certificate. The private key is used for signing server certificates that must be installed on the server. Whenever a service client calls the web service, the web service sends the server certificate including the public key to the client. The service client can validate the server certificate using the already installed public CA certificate. The client and the server can now use the public and private server certificate to exchange a secret key and thereby establish a secure SSL/TLS connection.
For more information about TLS: https://en.wikipedia.org/wiki/Transport_Layer_Security
Certificates have an expiry date. XProtect VMS will not warn you when a certificate is about to expire. If a certificate expires:
- The clients will no longer trust the recording server with the expired certificate and thus cannot communicate with it.
- The recording servers will no longer trust the management server with the expired certificate and thus cannot communicate with it.
- The mobile devices will no longer trust the mobile server with the expired certificate and thus cannot communicate with it.
To renew the certificates, follow the steps in this guide as you did when you created certificates.
When you renew a certificate with the same subject name and add it to the Windows Certificate Store, the servers will automatically pick up the new certificate. This makes it easier to renew certificates for many servers without having to re-select the certificate for each server and without restarting the services.
Management server encryption (explained)
You can encrypt the two-way connection between the management server and the recording server. When you enable encryption on the management server, it applies to connections from all the recording servers that connect to the management server. If you enable encryption on the management server, you must also enable encryption on all of the recording servers. Before you enable encryption, you must install security certificates on the management server and all recording servers.
Certificate distribution for management servers
The graphic illustrates the basic concept of how certificates are signed, trusted, and distributed in XProtect VMS to secure the communication to the management server.
A CA certificate acts as a trusted third party, trusted by both the subject/owner (management server) and by the party that verifies the certificate (recording servers)
The CA certificate must be trusted on all recording servers. In this way the recording servers can verify the validity of the certificates issued by the CA
The CA certificate is used to establish secure connection between the management server and the recording servers
The CA certificate must be installed on the computer on which the management server is running
Requirements for the private management server certificate:
  • Issued to the management server so that the management server's host name is included in the certificate, either as subject (owner) or in the list of DNS names that the certificate is issued to
  • Trusted on the management server itself, by trusting the CA certificate that was used to issue the management server certificate
  • Trusted on all recording servers connected to the management server, by trusting the CA certificate that was used to issue the management server certificate
Encryption from the management server to the recording server (explained)
You can encrypt the two-way connection between the management server and the recording server. When you enable encryption on the management server, it applies to connections from all the recording servers that connect to the management server. Encryption of this communication must follow the encryption setting on the management server. So, if management server encryption is enabled, this must also be enabled on the recording servers, and vice-versa. Before you enable encryption, you must install security certificates on the management server and all recording servers, including failover recording servers.
The graphic illustrates the basic concept of how certificates are signed, trusted, and distributed in XProtect VMS to secure the communication from the management server.
A CA certificate acts as a trusted third party, trusted by both the subject/owner (recording server) and by the party that verifies the certificate (management server)
The CA certificate must be trusted on the management server. In this way the management server can verify the validity of the certificates issued by the CA
The CA certificate is used to establish secure connection between the recording servers and the management server
The CA certificate must be installed on the computers on which the recording servers are running
Requirements for the private recording server certificate:
  • Issued to the recording server so that the recording server's host name is included in the certificate, either as subject (owner) or in the list of DNS names that the certificate is issued to
  • Trusted on the management server, by trusting the CA certificate that was used to issue the recording server certificate
Encryption to clients and servers that retrieve data from the recording server (explained)
When you enable encryption on a recording server, communication to all clients, servers, and integrations that retrieve data streams from the recording server are encrypted. In this document referred to as 'clients':
  • XProtect Smart Client
  • Management Client
  • Management Server (for System Monitor and for images and AVI video clips in email notifications)
  • XProtect Mobile Server
  • XProtect Event Server
  • XProtect LPR
  • ONVIF Bridge
  • XProtect DLNA Server
  • Sites that retrieve data streams from the recording server through Milestone Interconnect
  • Some third-party MIP SDK integrations
  • For solutions built with MIP SDK 2018 R3 or earlier that accesses recording servers: If the integrations are made using MIP SDK libraries, they need to be rebuilt with MIP SDK 2019 R1; if the integrations communicate directly with the Recording Server APIs without using MIP SDK libraries, the integrators must add HTTPS support themselves.
  • Certificate distribution
    The graphic illustrates the basic concept of how certificates are signed, trusted, and distributed in XProtect VMS to secure the communication to the recording server.
    A CA certificate acts as a trusted third-party, trusted by both the subject/owner (recording server) and by the party that verifies the certificate (all clients)
    The CA certificate must be trusted on all clients. In this way the clients can verify the validity of the certificates issued by the CA
    The CA certificate is used to establish secure connection between the recording servers and all clients and services
    • Trusted on all computers running services that retrieve data streams from the recording servers, by trusting the CA certificate that was used to issue the recording server certificate
    • The service account that runs the recording server must have access to the private key of the certificate on the recording server.
    If you enable encryption on the recording servers and your system applies failover recording servers, Milestone recommends that you also prepare the failover recording servers for encryption.
    Mobile server data encryption (explained)
    In XProtect VMS, encryption is enabled or disabled per mobile server. When you enable encryption on a mobile server, you will have the option to use encrypted communication with all clients, services, and integrations that retrieve data streams.
    Certificate distribution for mobile servers
    The graphic illustrates the basic concept of how certificates are signed, trusted, and distributed in XProtect VMS to secure the communication with the mobile server.
    A CA certificate acts as a trusted third party, trusted by both the subject/owner (mobile server) and by the party that verifies the certificate (all clients)
    The CA certificate must be trusted on all clients. In this way clients can verify the validity of the certificates issued by the CA
    The CA certificate is used to establish secure connection between the mobile server and clients and services
    The CA certificate must be installed on the computer on which the mobile server is running
    Requirements for the CA certificate:
    • The mobile server's host name must be included in the certificate, either as subject/owner or in the list of DNS names that the certificate is issued to
    • The certificate must be trusted on all devices that are running services that retrieve data streams from the mobile server
    • The service account that runs the mobile server must have access to the private key of the CA certificate
    Mobile server encryption requirements for clients
    If you do not enable encryption and use an HTTP connection, the push-to-talk feature in XProtect Web Client will not be available.
    If you select a self-signed certificate for the encryption of the mobile server, XProtect Mobile client will not be able to connect with the mobile server.
