This page is not yet available in your language.
Encryption
This section gives you an introduction to encryption and certificates.
XProtect systems support secure communication:
From
To
Recording server
Management server
Management server
Recording server
Clients, servers, and integrations that retrieve data streams from the recording server
Recording server
Mobile devices Mobile server
When do I need to install certificates?
  • If your XProtect VMS system is set up in a Windows Workgroup environment
  • Before you install or upgrade to XProtect VMS 2019 R1 or newer, if you want to enable encryption during the installation
  • Before you enable encryption, if you installed XProtect VMS 2019 R1 or newer without encryption
  • When you renew or replace certificates due to expiry
Introduction to certificates
Hypertext Transfer Protocol Secure (HTTPS) is an extension of the Hypertext Transfer Protocol (HTTP) for secure communication over a computer network. In HTTPS, the communication protocol is encrypted using Transport Layer Security (TLS), or its predecessor, Secure Sockets Layer (SSL).
In XProtect VMS, the secure communication is obtained by using SSL/TLS with asymmetric encryption (RSA).
SSL/TLS uses a pair of keys—one private, one public—to authenticate, secure, and manage secure connections.
A certificate authority (CA) can issue certificates to web services on servers using a CA certificate. This certificate contains two keys, a private key and public key. The public key is installed on the clients of a web service (service clients) by installing a public certificate. The private key is used for signing server certificates that must be installed on the server. Whenever a service client calls the web service, the web service sends the server certificate including the public key to the client. The service client can validate the server certificate using the already installed public CA certificate. The client and the server can now use the public and private server certificate to exchange a secret key and thereby establish a secure SSL/TLS connection.
For more information about TLS: https://en.wikipedia.org/wiki/Transport_Layer_Security
In XProtect VMS, the following locations are where you can enable SSL/TLS encryption:
  • In the communication between the management server and the recording servers
  • On the recording server in the communication with clients, servers and integrations that retrieve data streams from the recording server
  • In the communication from clients to the mobile server
For more details on the below references about certificate distribution, download the XProtect VMS Certificates guide from the Milestone website. (https://www.milestonesys.com/support/help-yourself/manuals-and-guides/).
Certificate distribution
The graphic illustrates the basic concept of how certificates are signed, trusted, and distributed in XProtect VMS.
A CA certificate acts as a trusted third-party, trusted by both the Subject/owner (server) and by the party that verifies the certificate (clients) ( see Create CA certificate).
The public CA certificate must be trusted on all client computers. In this way the clients can verify the validity of the certificates issued by the CA (see Install certificates on the clients).
The CA certificate is used to issue private server authentication certificates to the servers (see Create SSL certificate).
The created private SSL certificates must be imported to the Windows Certificate Store on all servers (see Import SSL certificate).
Requirements for the private SSL certificate:
  • Issued to the server so that the server's host name is included in the certificate, either as subject (owner) or in the list of DNS names that the certificate is issued to
  • Trusted on all computers running services or applications that communicate with the service on the servers, by trusting the CA certificate that was used to issue the SSL certificate
  • The service account that runs the server must have access to the private key of the certificate on the server.
Certificates have an expiry date. XProtect VMS will not warn you when a certificate is about to expire. If a certificate expires, the clients will no longer trust the server with the expired certificate and thus cannot communicate with it.
To renew the certificates, follow the steps in this guide as you did when you created certificates.
