Views
Views are located on the Live and Playback tabs and contain cameras and other types of content. If views have been assigned shortcut numbers (see Assign shortcut numbers to views), you can select a view by using keyboard shortcuts (see Keyboard shortcuts (explained)).
Searching for views and cameras (explained)
You can search directly for available views and cameras. Not only by searching for names, but also by searching for description, type and keywords.
You can find an overview of common keywords if you click
next to the search field.
You can see matching results for views and cameras while you enter text.
When you search for cameras in live and playback mode, you can view the cameras in a temporary view that is optimized for the amount of cameras you select.
You can click a single camera to view it in a 1:1 view, or you can click the heading of the camera results to view all discovered cameras (or the first 25). You can also select cameras manually if you press either CTRL or Shift while clicking one or more cameras. Press Enter to view the cameras.
You cannot create new views based on temporary views.
- Name
- Description
- Capability:
- PTZ
- Audio
- Input
- Output
- Views containing a specific camera
- Recording server name or address (shows connected cameras)
Your system administrator can add free text tags in the camera description field on the surveillance server to make it possible to group cameras and search for these tags. An example could be that all outdoor cameras use the tag "Outdoor" in the description field. In that case, all cameras of this type can easily be found.
Change cameras in views
You can temporarily change the cameras that are displayed in a view. However, it does not permanently change the view. If you want to permanently change the content of a view, you must be in setup mode.
You cannot change cameras if the view contains a hotspotA particular position for viewing magnified and/or high quality camera images in XProtect Smart Client views., carouselA particular position for viewing video from several cameras, one after the other, in a view in XProtect Smart Client., or MatrixA product integrated into some surveillance systems, which enables the control of live camera views on remote computers for distributed viewing. Computers on which you can view Matrix-triggered video are known as Matrix-recipients. (see Matrix (explained)) content. If used from the Cameras pane, the feature works with Smart Wall (see XProtect Smart Wall (explained)) positions as well.
Steps:
- Select the relevant position in the view.
- Do one of the following:
- In the Cameras pane, drag the relevant camera into the position in the view.
- On the camera toolbar, click More > Send to window > Main Window, and then select a position in the view.
- To restore your original view, click
on the workspace toolbar.
In the Cameras pane, the list of cameras is grouped by server. If a server is listed with a red icon, it is unavailable, in which case you will not be able to select cameras from that server.
Swap cameras
You can temporarily swap two cameras in a view. The camera in that position then exchanges places with the one you swap it with. You can only swap cameras with other cameras. This can be useful, for example, if you want to keep all your most important cameras in a certain position in your view.
Steps:
- Click the relevant camera title bar and drag it to a new position.
- To restore the original view, click
If you want to make permanent changes to your view, you must first be in setup mode.
Send video between open views
You can send video from a selected camera position to a single-camera position in another open view, including any views you may have in floating windows or on secondary displays.
This feature is not available for hotspots, carousels, or Matrix positions.
Steps:
- On the camera toolbar, click More > Send to Window.
- Select the destination view, and then select the position in the view where you want the video for that camera to display. If some of the camera positions are not selectable, they might be unavailable or used for hotspots, carousels, or Matrix content.
Send views between displays
You can send a view to a specific display or a floating window. This is useful, for example, if you have several monitors. Afterwards, you can synchronize the time of the destination display with the time used in the main window.
- In the Views pane, right-click the relevant view.
- Click Send View To and then specify how you want your view to display.
If more secondary displays are available, they will be numbered.
- To synchronize the time between the two displays, click Link window in the upper-right corner. The timeline is hidden in the destination window, but is still visible in the main window.
Any hotspots, carousels, Matrix positions, still images or HTML pages included in the view will work as usual in a floating window.
Multiple windows (explained)
You can send individual views to separate windows or displays, while keeping the main window of the XProtect Smart Client in the background, so you can watch several views simultaneously. The selected camera or item is always displayed with a blue border.
You can send any view to:
- A primary display to show the view in a separate full-screen window on your computer's main display with the main window hiding behind it
- A secondary display to show the view in a full-screen window on another monitor (if available)
- A floating window to show the view in a small separate window. You can use any number of floating windows and you can resize these to suit your needs.
Your view setup is stored in the XProtect Smart Client, so next time you log in, you can reuse it. However, this only applies to the computer on which you set it up. If you want to use multiple windows with the XProtect Smart Client on more than one computer, you must configure your multiple window setup on each computer.
For more information, click the expanding links:
Shows the window in full screen with the tabs and controls hidden. To display the tabs and controls, click the Toggle full screen mode icon:
Example of a view sent to the Primary display. While you are viewing the separate full screen window, the main XProtect Smart Client window is hidden behind it.
Example of an 8×8 view sent to a Secondary display. In this example, the main XProtect Smart Client window is available on the left display.
Shows the selected view, with the Live and Playback tabs. You can select a new view from the toolbar by clicking the dropdown button. You can toggle between displaying the floating window as a full-screen with no tabs and as a smaller floating window with tabs by clicking the Toggle full screen mode icon:
. You can also choose to link the floating window to the main window to synchronize time or to follow the Live or Playback tab.
Example of a view sent to a Floating window. The main XProtect Smart Client window is immediately available behind the floating window.
Was this article helpful?
Thanks for your feedback!
