Feature overview
The features available in XProtect Smart Client depend on your user rights and which of these systems you are using:
- XProtect Corporate
- XProtect Expert
- XProtect Professional+
- XProtect Express+
- XProtect Essential+
For information about the features available in your XProtect VMS, see Surveillance system differences.
Name |
Description |
Workspaces |
Task-oriented tabs:
Tabs for XProtect add-ons:
General features and personalization |
View handling |
Matrix | Through the Matrix, send or receive video from any camera to any Matrix recipient on your network. |
Alarm handling |
Audio |
With two-way audio support in live mode, you can:
Bookmarks and search |
Bounding boxes |
Camera navigator | Switch between all cameras that cover a specific area, for example a floorplan. This is useful, for example, if you want to follow a suspect who moves inside a building. As the person moves, you can switch to the next camera. |
Carousels | If you want one view item to shift between selected cameras, set up a carousel. |
Digital zoom |
Evidence locks |
Export and print |
Hardware acceleration |
Improve the video quality and viewing performance by rendering video using hardware accelerated decoding. Particularly useful when you view multiple video streams that have a high frame rate and high resolution. |
Hotspots |
HTML pages | Incorporate HTML pages into your views, for example to combine an online news channel with a set of cameras. |
Independent playback |
Input, output, and events control |
Use input from external units to trigger rules in the VMS system, for example a rule that starts recording. Activate or deactivate functionality in output devices, for example starting or stopping a siren. You can control output devices manually or by setting up rules server-side. |
Login authorization | Increase the system security by enforcing that XProtect Smart Client operators during log-in must be granted access to the system by a second person or supervisor. |
Manual recording | Record video manually from cameras on the Live and Playback tab. |
Map function |
Motion search and smart search |
Playback timeline |
Privacy masks | During export, you can mask specific areas in the recordings, for example to hide the identify of someone. You do this one camera at a time. |
PTZPan-tilt-zoom; a highly movable and flexible type of camera. |
Smart map function |
Snapshots | Take instant snapshots from cameras on the Live and Playback tab. |
Storyboarding | Include video sequences from different or overlapping time intervals from different cameras in the same export. |
System monitoring | Get an overview of the current state of your servers, connected devices, and the computer running XProtect Smart Client. This includes system performance. |
XProtect Smart Wall |
Through XProtect Smart Wall, you can set up video walls to share video, alarms, maps, bookmarks, and text information with other operators. |
User interface languages |
Supported languages:
Help languages |
The help function (F1 key) is available in these languages:
Was this article helpful?
Thanks for your feedback!
