Disable the help
To prevent operatorsA professional user of an XProtect client application. from accessing the help function, you can disable the help. Then nothing happens when you press F1, and the context-sensitive links and Help buttons are no longer visible. If required, you can enable the help again.
The availability of the help can also be controlled server-side by your system administrator. You can only disable or enable the help if the system administrator has not locked this setting.
Steps:
Open the Settings window. It opens on the Application tab.
- In the Online help list, select Unavailable.
- Close the dialog.
- To test that the help has been disabled, press F1. Nothing should happen.
Was this article helpful?
Thanks for your feedback!
