Locate the serial numbers
Your Milestone Husky unit and hard drives have unique identification codes called serial numbers. When you contact your Milestone reseller about your unit, always provide your reseller with the serial numbers.
Find the serial numbers in the software and on labels attached to the hardware.
Serial numbers in the software
Find the Milestone Husky unit serial number in Husky Assistant:
Find the serial numbers of the hard drives in MegaRAID Storage Manager:
Serial number labels
Find the Milestone Husky unit serial number on the back of the unit.
Locate the barcode that has the serial number.
Scan the barcode to see the serial number.
You can also scan the QR code to get to the Milestone Husky support and information page. (https://www.milestonesys.com/HuskyX8-support/).
Find the hard drive serial number on the front of the hard drive.
Was this article helpful?
Thanks for your feedback!
