This page is not yet available in your language.
Before you install XProtect DLNA Server
When you install XProtect DLNA Server, you install a server and a plug-in for the Management Client. These components enables you to add DLNA channels and provide video to DLNA devices.
You can install and add multiple DLNA servers to your XProtect system. Multiple DLNA devices are able to connect to each DLNA server, so this increases the load on the network, and can impact performance. To reduce the overall use of network resources on the computer that runs the management server, install XProtect DLNA Server on a separate computer.
Installation requires a restart of Event Server service and Management Client
Milestone recommends that you go through the preparation described in the next sections, before you start the actual installation.
