This page is not yet available in your language.
View LPR server information
To check the state of your LPR servers:
  1. In the Site Navigation pane, expand Servers and select LPR servers.Go to the Overview pane.
    The LPR server information window opens with a summary of the server status:
    • Name
    • Host name
    • Status
  2. Select the relevant LPR server and review all details for this server.
LPR server information properties
Field
Description
Name
Here you can change the name of the LPR server.
Host name
Shows the LPR server host name.
The first part of the name of the LPR server consists of the name of the host computer for your LPR server installation. Example: MYHOST.domainname.country.
Status
Shows the status of the LPR server.
If the server has just been added, the status is:
  • No LPR cameras configured
If the system is running without problems, the status is:
  • All LPR cameras are running
Alternatively, the system returns:
  • Service not responding
  • Not connected to surveillance system
  • Service not running
  • Event Server not connected
  • Unknown error
  • X of Y LPR cameras running
Service up time
Shows the up time since the LPR server was last down and the LPR Server service started.
Computer CPU usage
Shows the current CPU usage on the entire computer with the LPR server(s) installed.
Memory available
Shows how much memory is available on the LPR server.
Recognized license plates
Shows the number of license plates that the LPR server has recognized in this session.
LPR cameras
Shows a list of enabled LPR cameras that run on the LPR server and their status.
LPR cameras available
Based on your license, this number shows how many additional LPR cameras you are allowed to add and use on all your LPR servers in total.
Country modules available
Based on your license, this number shows how many additional country modules you are allowed to use on all your LPR servers in total. It also lists the number of country modules already in use.
