Wizard for access control system integration
The Access control system integration wizard is for step-by-step configuration of the initial integration with an access control system. Use the wizard to get through the most basic configuration tasks. You can do more detailed configuration afterwards.
Before you start the access control integration wizard make sure you have the integration plug-in installed on the event server.
Some of the fields to fill out and their default values are inherited from the integration plug-in. Therefore, the appearance of the wizard may differ depending on the access control system you integrate with.
To start the wizard, select Access Control in the node tree, right-click, and click Create new.
Was this article helpful?
Thanks for your feedback!
